10-14-2023 11:44 AM
Good afternoon. We recently switched to a new internet provider and I was unable to get two google cams to connect with the new WiFi so I removed them from the Google home App but I am unable to get them connected as a new device. I have tried everything. The third camera was able to connect via the Nest App but when I try to add the additional two cameras on Nest, it says I must do so on the Google home app. I scan the QR code, go through all of the prompts and get to the final stage which always says unable to connect. Any advice? Much appreciated.
10-14-2023 02:07 PM
After removing them from the Google Home app, did you factory reset them?
Restart or factory reset Nest camera or doorbell - Google Nest Help
10-14-2023 02:20 PM
Thank you! That solved my first problem. They are both on line now but one camera won’t show any video. It says it’s offline. Any ideas?
10-14-2023 04:15 PM
That could be caused by quite a few things.
Troubleshoot offline Nest camera or doorbell - Google Nest Help
See the "Only your camera or doorbell is offline" section.
