04-12-2023 01:20 PM
I have accidentaly deleted a Home in which my only Nest Cam was set up.
It is now impossible to reconnect my cam to a new home, nor a new account (cam flashing white then never turns to blue).
If I want to facility retsore my cam ... it asks me to do it from Google Home and then my (lost) Home ... and I turn around in circle.
Please help 😞
thanks so much
04-12-2023 01:38 PM
If you have the newer Google Nest Cam (wired), which gets installed in the Google Home app, you can do a factory reset by pressing the reset button for 12 seconds. "Locate the reset hole on the bottom of the camera head. It’s between the power cord and the camera neck."
If uni have the older Nest Cam Indoor, which gets installed in the Google Nest app, Google Nest's instructions say there is no reset button and you're supposed to remove it from your account in the Google Nest app:
They don't say what you're supposed to do if you can't do that, but I've seen a few posts in this forum where Google Nest Community Specialists have said to unplug the camera for a full 48 hours; judging from past posts, it seems that SOMETIMES works.
04-12-2023 04:50 PM
Thank you so much ! It worked ! I had never noticed this little reset button !
Thanks again
04-14-2023 02:54 PM
@JGMTL, thanks for getting back to us and we're glad that it's resolved now. We’ll consider this one complete so let us know if you have other questions or concerns as I will be locking this after 24 hours. Feel free to start a new thread and we'll be happy to help.
