01-15-2022 03:49 AM
New style battery doorbell is too firmly attached to take off to recharge. Using the tool at the bottom as advised or the top as in a previous solution doesn’t work. Any more suggestions? Thank you.
01-15-2022 07:48 AM
We have Nest Hello doorbells (where the release tool is inserted at the bottom of the doorbell) and not the new Google Nest Doorbell (Battery) (where the release tool is inserted at the top of the doorbell. Maybe the "Wired installation" video on the Google Nest Help website (https://support.google.com/googlenest/answer/10732535?hl=en&ref_topic=9300124#zippy=) will help. Starting about 4:38 in the video it shows inserting the release tool (or a flathead screwdriver) into the top of the doorbell and then pushing the doorbell straight up to release it. (The battery-powered installation video shows the same thing.) This is NOT how the Nest Hello doorbell is removed and I'm guessing the release tool (or flathead screwdriver) must trip or release some sort of latch that then allows you to slide the battery doorbell straight up in order to release it. Hopefully the visual in the video will help you. Good luck.
04-27-2022 10:27 AM
Thanks for visiting the Community. Since this thread hasn't had activity in a while, we're going to close it to keep content fresh.
We hope you were able to get the help you need, but if you're still having trouble, please feel free to submit another post, and provide as many details as possible so that others can lend a hand. Hope this helps!
