How to change WiFi settings without climbing to Nest Pro
Elizaville
my Nest Pro outdoor camera is installed 50 ft up in the air under the roof. I need to change Wifi settings on it (we got a better network), but I do not have a lift and would like to avoid calling expensive people to climb there.  How could I update WiFi settings without reading QR codes?
please help
Rubes
Unless I misunderstood, with the Outdoor cam can’t you change the WiFi settings from within the app?
I have the Outdoor IQ and within the Nest app and settings option for the camera, there is a WiFi connection setting that walks the user through making WiFi changes within the app.
Can you maybe clarify which camera you have? I’m not familiar with the “Nest Pro”.  Is it the Outdoor IQ, the regular outdoor cam or one of the newer battery-only ones?
2 REPLIES 2
Rubes
Elizaville
Thank you so much for reaching out. I was able to connect because I found a picture of the back of the camera made before it was mounted under the roof. Have a nice day
