How to flip Nest 2.0 wired camera 90 degrees?
akruss
How to flip Nest 2.0 wired camera 90 degrees? Only gives the option to flip 180 degrees
JillG
Hi akruss,
I only know of the setting for 180 degrees. If it is installed at an odd angle you will need to twist or turn the camera to adjust.
akruss
Thanks. The camera cannot be flipped. I wish I could turn it, like the Original Nest camera (black).
JillG
It would be helpful to have other options beside the 180. I think most uses need the 180 but like you, there are other situations.
Hopefully Nest can add those options, but for now, only the one preset option exists.
P.S Thanks for your help, @JillG!
Hey Folks.
