How to increase the volume when talking through the camera?
Robert651
How do you increase the talk volume when talking through the camera. The volume is so low it’s barely audible. Person is next to the camera and can hardly hear me when talking through the camera.
6 REPLIES 6
Rubes
I’m not aware of an option to modify volume levels of the Nest cameras. Perhaps it is a hardware issue?
Robert651
There are numerous community incidents with the same issue. Do you think everyone is having a hardware issue? I think a little more problem diagnostics  needs to be done. You may want to examine the last few firmware/app updates to see which one may have lowered the volume. If an intruder can not hear you from the outdoor camera it's almost useless.
Just checking in to see if you still need assistance with this issue.
P.S Thanks for your help, @Rubes!
Robert651
Yes, issue has not been resolved. Please address the issue
@Robert651
There is no such option to adjust volume levels on Nest Cams or Doorbells. Your issue sounds like it could be a hardware-related issue. I would Factory Reset your device, and go from there. I wanted to remind you of some Important things to know before you factory reset. After you factory reset your camera or doorbell:
  • Your camera will forget your Wi-Fi network name and password.
  • Your camera will be "Offline" in the app. You won't be able to use it until you remove it from the app and reconnect it.
  • Any custom camera settings will revert to default settings.
  • If you want to save any video footage, before you factory reset, create video clips or timelapses and download the files to your phone or computer.
  • If you have a Nest Aware subscription and you plan to continue using your camera or doorbell with the same account, do not cancel your subscription.
  • If you plan to get rid of your camera or add it to a new account, before you factory reset, cancel your Nest Aware subscription. After you cancel, your camera's entire video history, Activity Zones, and snapshots will be erased as soon as you remove your camera from the app. Once your video history and snapshots are deleted, they're gone forever. They cannot be recovered. We do not keep backups.
Important: Because a factory reset permanently erases the items listed above, we don’t recommend doing it as a troubleshooting step until you’ve tried restarting your camera and other troubleshooting options.
Hey Folks.
