11-26-2021 09:28 AM
I have two Nest Cam Battery cameras that I will not be using for a while. What is the correct way to shut them down so that they don't keep using the battery? I want it so that the next time they are connected to power that they start up, like when taken out of the box for the first time. The instructions for Factory Reset seem to suggest that they'll reboot and still be powered on.
01-09-2022 12:11 PM
Turning off the camera isn't the issue - I can do that from the app. But on the Battery cam, the cam stays alive, listening for WiFi commands. It does seem, though, that after some undetermined time of the camera being off and the power disconnected, that the cam does shut down. When I took one and reapplied power, it went through its startup sound and was still connected to my account.
12-04-2021 05:24 PM
Anybody?
01-06-2022 10:03 AM
I apologize for my late response and thank you for all of your patience while waiting for a reply. I can definitely understand how frustrating your situation must be, but I wanted to make sure that your issue was addressed. Note: If you have more than one camera, you can also switch each of your cameras on or off in the same place in the app.
Note: If your camera is already turned off, you’ll also find Turn on camera near the bottom of the live view screen.
This should allow you to turn off the camera, and then unplug it and see if that does the trick. It will not be like it was when you first opened the box, but it could work for you next time you want to use them. If not, you would just plug them in and charge them before use.
01-09-2022 12:11 PM
01-20-2022 12:20 PM
Hey Folks.
I am glad to hear that the issue is resolved! At this time, I'll go ahead and lock this thread. If you're still experiencing problems, feel free to start a new thread and we'll be happy to help.
