How to use Nest Audio as a real chime for Nest Doorbell? (Maybe a feature request)
JaapH
Hi there is a possibility to announce visitors on a Next Audio/Google home with the Nest Doorbell. However when somebody has put the volume of the device to zero or quite low you won't hear it.
What I would like is that I can set a chime with a set volume and even better would be that you can select the chime with a certain length E.g. ding dong that sounds for 3 seconds
Or is this already possible?
catheryn
Hello @JaapH
Thanks for bringing your concern to our attention and posting it in the community.
I understand you have some questions about Nest Doorbell chime settings. No worries, we're here to help!
Adjusting the chime length is possible for Nest Doorbell (wired models only).
Here's how:
  • Open the Home app.
  • Tap and hold your device's tile.
  • Tap More.
  • Tap Settings.
  • Select Doorbell.
  • Slide the ring length node to decrease or increase the chime duration.
Additionally, you might find this article helpful: Change Nest Camera and Doorbell audio settings.
Let us know if you need further assistance. We're ready to help!
Catheryn
catheryn
Hello @JaapH
Here's how:
  • Tap More.
  • Tap Settings.
  • Select Doorbell.
Catheryn
