I have a nest doorbell that worked perfectly for few months. At a sudden moment the doorbell stopped
jatinxdhawan
I have a nest doorbell that worked perfectly for few months. At a sudden moment the doorbell stopped working. Connection was lost and only the green light on top kept blinking. Please suggest what can be done.
canosoup
Hopefully it’s under warranty. Otherwise you’re screwed. You’ll probably have to fill out a support ticket and wait a couple months.
I have one of my Google nest cameras go bad 30 days after the warranty and Google won’t replace it! When this was nest, they would replace any broken camera because they valued their customer subscription.
WYZE cameras are ¼ the price with better quality . one you can rotate 360°, the subscription is way cheaper. They also have a responsive support troubleshooting section.
Thanks for the response. But is there no solution on why Green light keeps blinking and how can we fix it.
Really strange how such a branded item become a scrap in no time and with no reason.
EdmondB
Hey everyone,
@jatinxdhawan,I'm sorry to hear you're having issues with this. No worries, we'll figure it out together. Just to be sure, did anything change with your Wi-Fi network or power when this happened? Also, have you tried resetting your Nest Camera Battery to its factory settings?Check out this link on how to Restart or factory reset Nest camera or doorbell.
Edmond
