Indoor Chime not working, possible defective chime connector?
unclepoppajohn
Hello, i seem to be having a very similar issue to this post:
https://www.googlenestcommunity.com/t5/Cameras-and-Doorbells/Indoor-chime-stopped-working-Chime-Conn...
Here is my current setup:
  • wired doorbell, wired mechanical chime
  • 20.6 V (measured using multimeter) from the transformer
  • 2 wires (i.e. one bell, one door, one chime)
I wired everything correctly, but the mechanical chime will not work (i.e. the hammers don't strike the bell - in fact the hammers do not move at all).  I conducted a test by removing that round white thing (capacitor?) and the chime hammers properly strike the chimes.  HOWEVER, there is a constant hum coming from the door chime.
When I re-introduce the round white thing, the hammers again don't move at all.
Is this a defective chime connector?  How do i get it replaced?
(FWIW, i did cut the ends off the round white thing and connected it all up using wire nuts - to no avail... same issue)
6 REPLIES 6
Rubes
Gold Product Expert
Gold Product Expert
Have you tried the ol’ chime duration trick? Maybe it will work, maybe not. With everything properly connected, from the settings menu choose “Chime Duration”. Toggle the setting on (even though you have a mechanical chime), wait a few seconds and then toggle off. Then try the outside bell button.
Yes, i've tried that - i've tried everything from factory reset to a new 24v transformer to 'hard connecting' the round thing to the doorbell/chime/transformer wires.  No matter what i've tried, every time the round thing is in the circuit, the chime hammers don't move.
I have precisely the same issue, but my transformer is a Nutone 10VA: a 16 volt 10 amp transformer.  The voltmeter measures 17 volt output at the transformer and at the indoor chime.  Without the "Chime Connector", which Nest help personnel seem to suggest is a surge protector, the chime works fine with the new Nest doorbell.  Put the "chime connector" in the circuit, however, and I get nothing on the indoor chime.  I have tried the "lengthen the chime duration" technique, and it does nothing, except that with the lengthened chime duration and no "chime connector" the indoor chime will hum for the period of lengthening and then fire.
During my last episode with Nest help (which seems staffed by generally inept individuals who read from scripts), I asked whether it was possible that there was a voltage issue.  He seemed to be able to test voltage remotely and indicated that he read 14 volts, that he could not help me with that, and that I needed to hire a "professional installer."  After hanging up I tested with a volt meter and read 17 volts.  My chime is one of the most common chimes manufactured by the largest chime manufacturer (Broan-Nutone) and if this is inadequate voltage, then Google-Nest is guilty of false advertising.  They are, at a minimum, guilty of making help unavailable (hold times over an hour) and providing not helpful help.
I was thinking of purchasing a new chime transformer but am uncertain it would resolve the issue and I cant get anyone from Nest to answer my question.  Did you resolve your issue? Has anyone else had this issue?  Is there an email address where intelligent humans answer help questions (the Nest people on Chat clearly do not).
Hi There,  I heard back from Nest support and they told me I have a defective 'puck' - but they also told me that my unit is now out of warranty so they cannot send me a replacement.  When I asked where I can purchase a replacement puck, they said that they are not available to purchase separately.
I also doubt that your transformer is the issue - mine was reading 17v before replacing it and it now reads 20v - same issue.
I would suggest trying to get a replacement puck as soon as possible (before your warranty runs out)...  if you're warranty has already run out, then you'll find yourself in my exact predicament - out of luck.
Hi there!
@Rubes thank you for helping out on this thread! I appreciate your help.
Just checking in to see if you still need assistance with this issue.
Hey Folks.
