02-28-2024 08:21 AM
My electrician has asked for an installation manual and electrical specifications for the Nest Cam Floodlight.
I can't find documentation online anywhere and Google Support doesn't know their products. There was no documentation in the box.
Where can I download the installation manual?
02-28-2024 04:31 PM
I think they only have these online instructions, which include a video:
03-04-2024 08:30 AM
Unfortunately I can't email or print out a video to my electrician. There's also nothing that answers their questions about if special boxes are needed for mounting the floodlights.
I'm blown away that Nest/Google have nothing in print. Every other electrical fixture on the market comes with some kind of installation manual and spec sheet.
03-04-2024 08:44 AM
You are correct.
03-04-2024 12:32 PM
Hi pcorning,
We really appreciate you taking the time to share your thoughts and feedback with us. It's super helpful and makes a big difference in making our products even better. If you have any thoughts or comments about Google Nest, please do share feedback about Google Nest. If you need anything else, just let us know we're always here to help.
Edmond
03-06-2024 11:50 AM
I think I'm all set, but I definitely have feedback. The link you sent for providing feedback is not helpful. I would have to speak out, or write out, everything on my phone or smart display. Is there a web form or email instead?
My feedback from this topic:
-Phil
03-06-2024 12:13 PM
I agree that the lack of a written installation manual is a serious drawback. Other customers in this forum have asked about the dimensions of the electrical box on which the floodlight camera can be mounted, and there are no answers.
The installation video, at about 2:10 on the video, shows directions for a green grounding wire that's supposedly included.
I don't know anything about Google's "Nest Pro" program, but if you go to the "Professional installation and service" page on Google Nest Help (https://support.google.com/googlenest/answer/9232427) and select "US and Canada" and then select the "Ontech" link under "Contact Ontech for basic installation and setup with the app", you get an OnTech page titled "Let's get your Google Nest set up and running" (https://www.ontechsmartservices.com/pages/nest) with with options and prices for installing various Google Nest products. I've never used OnTech, so I can't speak to how well it works.
03-06-2024 12:22 PM
The Google support pages you linked are incorrect, as are Ontech's own pages. I personally contacted Ontech and they no longer do Google Nest installation. They are no longer certified to do it.
I'm not sure what is going on with Ontech. From my communications with them, it sounded like it may be a fairly new change that they no longer install Nest products?
I'm finding there's a lot of old or incorrect information at support.google.com and in the pages it links to. 😞
03-06-2024 12:37 PM
Boy, that's really odd on OnTech's part! On that OnTech web page, I can add an install to a "cart", select "proceed to scheduling", select a time for the install (starting as soon as tomorrow in our zip code), and get a checkout page that includes entering our service address.
On the main OnTech page, you can shop for Google Nest products, and they each present an option for a professional install. Oddly, though, the Google Nest floodlight camera is NOT listed anywhere. Maybe because, since the floodlight camera is hard-wired, it requires an electrician if you're hiring someone.
