Integrate Ring cam into Google Home?
Rjkanes
Is there anyway to add a Ring cam onto my Google Home devices? It's not listed under "add a device." Seems like there should be a way to just use it as a generic device, even with reduced functionality. Older webposts indicate you can add it under "add a device," but that doesn't seem to be the case. This should work... it's basic device management and should be platform agnostic. Pls advise, thx!
2 REPLIES 2
EmptyNester
Silver Product Expert
Hello,  I'm an end user like you.   That may have been possible a number of years ago but the way I understand it Google about 2+ years ago significantly closed their system to other products for security reasons.
David_K
Ring isn't a service that integrates with Google Home, probably because it's owned by Amazon.
I have Reolink security cams and they integrate with Google Home as an example.
