09-03-2021 03:22 PM
Original poster: K Green
09-03-2021 08:52 PM
What device are you asking about? What type of router? How Close? Is there anything inbetween the units, especially metal objects?
09-08-2021 04:01 PM
Hi. This is a Nest Doorbell networked to an Asus ROG Rapture GT-AC5300 router located approximately 15 feet from device. The doorbell and router are on different floors, router being downstairs. The doorbell is installed on brick and next to a metal front door. The Nest doorbell is always delayed in relaying a signal out to our cellphones. I was curious, if this is to be expected with this device? I also have a Nest smart thermostat that has maintained a strong signal, though its path is threw floors with some metal between. Thanks for your help.
09-08-2021 04:05 PM
Metal doors are an Achilles heel of wifi .. use your phone to test the wifi where the nest doorbell is placed, with the door closed , and see if the signal is low there. That would be my suspicion. I had the same issue but re positioning the router solved it for me
09-08-2021 05:06 PM
From my experience the delay you are talking about is normal. I have had the original Nest HELLO and it can take anywhere from 2-8 seconds before my phone alerts me that someone pushed the button. The new Nest Doorbell (batter) is faster but there is a A LOT of problem with it. I bought it and test it for 2 days and decided the negatives far outweigh the positives so I returned it and went back to the old doorbell.
