Mechanical chime not working with replacement nest doorbell
marc-knuckle
Hi guys.
The doorbell was replaced under warranty. Before this my mechanical chime was working fine. Initially when i first ever got the Nest, the existing transformer wasn't up to the task. I think the V was sufficient but not the VA i think it was. Since i got an upgraded transformer it had been working fine.
Now i have the replacement Nest, a 1 to 1 swap i believed, the chime isn't working.
It is a mechanical one so it should work whatever setting is in the app but i made sure the indoor chime option was selected and it is.
Is there anything in possibly missing?
Cheers, Marc
1 ACCEPTED SOLUTION
marc-knuckle
Right.... Goodness knows why or how but it's suddenly started working again?? I haven't done anything since it wasn't working.
View solution in original post
2 REPLIES 2
marc-knuckle
Hey Folks.
Glad it is now working for you! At this time, I'll go ahead and lock this thread. If you're still experiencing problems, feel free to start a new thread and we'll be happy to help.
