04-24-2023 07:45 AM
Hello NEST Support.
I've had a Nest Doorbell for two years, and no problem. Then earlier this year, I began receiving multiple and many MOTION and SOUND notifications. I've worked with Nest Support to no real solution. So, bought a new Nest Doorbell, and configured it properly yesterday, 4/23. The problem remained. I've reinstalled the NEST App. Same problem remained.
Every sound (a bird singing or wind noise) and every motion (such a leaf falling or paper blowing down the street) cause notifications. Nest Support assured me that my notifications were correct.
My event notifications listing is full of these motion and sound indicators.
This problem seemed to have started when NEST transitioned under GOOGLE. Everything was working fine until early this year.
Any similar experience from anyone?
05-01-2023 10:50 PM
Hey KCH,
I appreciate the help here, everyone!
04-24-2023 08:44 AM - edited 04-24-2023 08:44 AM
Hi @KCH
Not sure I'll be able to help much as you seemed to get all the available help from Support.
I have a Nest Doorbell but use the Google Home app. I also have Nest Aware subscription.
My other cameras can use the Nest app and I have the notifications not to send any sound related ones to me. For those settings: Nest app: Camera>Settings>Notifications>Activity
The newer doorbell uses the Google Home app and that's what I use for mine. I turned Motion off, animals detected but no notifications and I have zones set up.
I just wanted to post and let you know how mine is set up. I don't get too many extra notifications.
Jill
04-24-2023 08:52 AM
Hi Jill, thanks for the quick reply. I've now turned OFF notifications>activity in the Nest App. I'll next open Google Home and turn of animals detection, etc., as well. I'll test this in the next 10 minutes.
Thanks again!
KCH
04-29-2023 07:44 AM
Hello everyone,
@KCH, thanks for reaching out here in the Community. To confirm, are you still receiving multiple motion and sound notifications? Let us know your update here.
I appreciate your help, JillG.
05-01-2023 10:50 PM
Hey KCH,
05-02-2023 03:03 AM
Hey JT
thanks for following up. The advice to access the Nest notifications and turn off sound and motion.
the problem is solved. Thank you
Regards, KCH
05-02-2023 03:06 AM
Hey JillG
thanks for following up. The advice didn’t solve the problem. I did get advice to access the Nest notifications and turn off sound and motion by JT. The problem is solved. Thank you
Regards, KCH
05-02-2023 05:25 PM
Perfect, we're glad to hear that! As we got our resolution here, I'm going to mark this thread as complete. I'll be locking this thread if we won't hear back from you again in 24 hours. Should that happen, feel free to create a new one if you have more questions or have other concerns in the future.
