Doorbell camera angle points too high.
GFS
Doorbell camera angle points too high. How can I change the vertical angle. Google help says there's a way in setup but that is not showing now. Would I have to add some washers to the back of the doorbell between the bell and the door molding at the top screw? Is there any other way?
David_K
The wedge Google provides does not allow you to adjust the vertical viewing angle unfortunately. Indeed, probably the best option is going to be to use small washers behind the wedge or baseplate to adjust the viewing angle up or down, as there doesn't seem to be any third party wedges that offer vertical adjustment.
@GFS
Do a Google search for "vertical wedge for 2nd gen google nest doorbell". Etsy has one for the 2nd gen doorbell. We have a similar one for our Google Nest Hello Doorbell.
GFS
Thanks MplsCustomer. That is what I was looking for.
Dan_A
Hi GFS,
As we got our resolution here, I'm going to mark this thread as resolved. I'll be locking this thread if we won't hear back from you in 24 hrs. Should that happen, feel free to create a new one if you have more questions or have other concerns in the future.
Thanks for helping, davidking and MplsCustomer!
Dan
