My Nest Door bell - Green light - but offline
Bakchoi
My Doorbell has been disconnecting on and off lately. Then finally, one day a couple of weeks ago, it disconnected and never connected again. At first,  I thought it was some issue with the power, but the green light on the doorbell is lid. However, the doorbell won't connect to wifi or the app. I tried restarting the doorbell, powering on/off. nothing worked.... any one have a better idea?
7 REPLIES 7
BigScrummy
I’ve had the same issue lately, would love help in this
@Bakchoi
One possible cause is an issue with your Wi-Fi network, either with signal strength, bandwidth, or certain Wi-Fi settings that are problematic for Google Nest cameras.
If you think it's not a Wi-Fi problem you could try contacting Support, starting with this link:
Hello MplsCustomer, Its definitely not Wifi. At first, I thought it was as well, but it's not. I am sitting beside my doorbell, and it will not connect with my phone, let alone the wifi part. I even added an extender right beside my door bell as well, but ya not connecting, nothing.
Thanks for the support link though. much appreciated.
janthadeus
Thanks for taking some steps beforehand — these are of great help! It looks like it’s not getting any power from your transformer. Let’s sort this out —  a few questions: what’s the voltage of your transformer? How’s the temperature of the doorbell (warm, hot, cold or normal)? What country are you located in? Has there been any recent power outage in your area? Also, has it been exposed to direct sunlight?
Here are some troubleshooting steps you can try:
  1. Ensure the wires are connected securely into the doorbell.
  2. Remove the wires from the doorbell then use the included USB cable to plug your camera directly into a USB port on your computer.
  3. When the light pulses blue, wait for a couple of minutes to reconnect it to your Wi-Fi. Otherwise, your doorbell is dead.
  4. Mount your doorbell to the wall plate.
Important: When the doorbell shows a blue pulsing light when connected to a computer, it means it’s working. There may be issues on your wires or transformer. I recommend scheduling a visit with our partnered Nest Pro
janthadeus
It's me again. I want to make sure you're all good — how did the steps go?
Hey JT, im done with the doorbell.. i cancel my subscription for nest aware and looking at replacements. pretty disappointed with a google device.
janthadeus
Hi Bakchoi,
We're sad to see you go. We hope we can make it up to you in the future. We're always here to help if you ever change your mind. Please let me know if you have any other questions or concerns as I will be locking this in 24 hours.
