My Nest Doorbell stopped working after 2 years hardwired but has power using USB connector.
mdj
My Nest Hello worked fine hardwire with the previous doorbell wires. I measured the volt with a multimeter and was ranging 24-25V and every worked for a couple of years. Now there's no power connected to the hardwire. Wire still reads 24-25V. I tested the Nest doorbell using the USB power supply and it turns on and everything works. Could there be a hardware issue? Any ideas how to solve the problem? Thank you for your help!
mdj
I just rechecked all my connections and the volt is 28V all around from the transformer all the way to the doorbell wire. Any help from anyone?
Sorry for my late response. Thank you for all of your patience while waiting for a reply. I just wanted to make sure that your issue is addressed. I can definitely understand how frustrating your situation must be. I would love to help you find a solution to this issue.
  • Do you still need help with this issue?
  • What troubleshooting steps have you done thus far?
Jeff
Hi, everyone.
Thanks
