My doorbell camera won’t reset solid blue light
Jccalixto99
have new wifi net work
restarted my nest camera fine
anf al my devices at home but my doorbell I had to remove it and add product now it says I need to factory reset I press button and put pin on back simultaneously but won’t reset it stays with a solid blue light and that’s it
Lance_L
Hi Jccalixto99,
Thanks for reaching out to the Community. I’d be happy to help you with the Nest camera. Let’s check it out.
A few questions: what model of Nest camera do you have? Do you use the Google Home app or the Nest app to set up the device?
Here’s a handy guide on how to restart or factory reset a Nest camera or doorbell.
Let me know how it goes.
Lance
