Nest Battery Camera reset and WiFi change.
Mo1357
I have reset my camera. I have the blue light indicating it's ready for set up. It tells me it's connecting, but after time it tells me it can't connect and move closer to the WiFi network. My camera, router, and phone are all near each other. It tells me I need to make sure the phone and camera are on the same WiFi. The Nest and Home app don't show me the WiFi network. I don't have a "tile" for the camera as it is not fully installed. How can I find or enter that information?
sicsacol
Hi Mo1357,
Thanks for reaching out, I'm sorry to hear that you're having trouble connecting your Nest Camera. Don't worry I can help.
Here are some troubleshooting steps you can try:
Keep me updated.
Jonathan
