Nest Battery Doorbell
AngJustAng
So, apparently even if you check for the doorbell being secure, a door closing can cause the doorbell to fall off. Now I know Google won't replace it due to it not being their fault but can I fix the camera lense? It's cracked without a proper view of any person or thing. Or is it just ruined now?
Thank you for your patience. Please fill out this form so we can collect some important information from you. Once the form is submitted, you will have your case number.
