12-15-2021 02:40 PM
I purchased 4 google nest cam battery. All of them connect to the wifi without problem. However, when I get to the end, it states "Setup is taking longer than expected, try again later". I've been at this for HOURS now. What's going on? I'm about to just head back to Best Buy and return these camera.
Please help the community out!
12-16-2021 07:38 AM
Mine worked.. no app update
12-16-2021 07:26 AM
Still not working for me. Nothing happens when I click “finish setup”. I even deleted and downloaded the app again.
12-16-2021 07:31 AM
I'm not sure which product you're trying to complete setup on, but for the product that I was trying to complete the setup on (doorbell), I had to hard reset the thing and then was able to work through the setup.
I hope that helps...
12-16-2021 07:37 AM
Try removing the cam from your device list. Resetting the camera and adding it from scratch again. That works for me on all of the cameras.
03-03-2022 08:47 AM
12-16-2021 01:37 PM
Setup works again but interestingly under events on the Next Doorbell (battery) it comes up "problem connecting to Cloud". Restarted Router etc.. wonder if the app still has issues and they only deployed a server end workaround.
12-16-2021 01:45 PM
Disregard.. changing the colour of the event location actually fixed it <boggles>
12-16-2021 07:05 PM
yep, its fixed... no official acknowledgement from Google that I have seen though...
12-18-2021 11:40 AM
Battery doorbell and cameras still don’t work for me.
12-18-2021 12:02 PM
Battery cameras and doorbell just flash white and “something went wrong” message appears. So frustrating.
03-26-2022 08:31 PM
I've been struggling with two out of 4 of these battery cameras. I can't get it to set up no matter what I do. And I have 10 other nest cams/thermostats/smoke detectors. I never had any issues with Nest until google took over and introduced these new cameras that only work with Google Home. I can't belive they ruined something that worked so easily.
I need to add more cameras to my new house, but if this is the future or nest I'd rather ditch these and start over with simplisafe or a custom system.
