08-16-2023 07:48 AM
Bought a couple of Nest Cam Wired Indoor cameras some time ago. One I'd been using and one just sat in the box for some time.
Got it out today to try and set it up but can;t get it to work. Oddly the blue light on the front of the camera is just solid, and I'm pretty sure it should be blinking.
I've looked at resetting it but there are mixed reports on whether it has a reset button or not. There is a hole to the left of the power socket but it doesn't feel like a button when you push a paper clip in.
08-16-2023 08:19 AM
Here are Google Nest's restart and factory reset instructions.
The newer indoor camera's reset button is between the power cord and the camera neck. This camera was released Aug 24, 2021. (https://store.google.com/us/product/nest_cam_indoor?hl=en-US)
The 1st gen indoor camera does not have a reset button.
https://support.google.com/googlenest/answer/9252162
The 1st gen indoor camera has a solid blue light documented: "Starting up or restarting":
If you have the older 1st gen indoor camera, which hasn't been sold for 2 years now, perhaps it has an out-of-date firmware version that doesn't work with the current Google Nest app or the current software on Google Nest's servers.
I've seen several recent posts from customers who are trying to newly install Google Nest devices that are several years old, and are having trouble doing so. Google Nest does not seem to have any way to cope with this situation, since there is no way to update the firmware without first installing the Google Nest device and getting it connected to Wi-Fi, and the device cannot be installed because the firmware is out-of-date.
08-20-2023 02:28 PM
Hello WhatARob,
Thanks for reaching out to our Community. I'm sorry to hear you're having issues. Let's take a look and see what we can do.
As MplsCustomer pointed out, your Nest Cam Indoor doesn’t have a reset button. Also, the solid blue light is normal when you first plug your camera into a power outlet, when your camera restarts itself after a power outage or firmware update, or when it is waiting to be added to an account.
Let’s try the troubleshooting steps below:
If the issue persists, take note of any error codes and report them back here.
Keep me posted.
Lance
