12-28-2021 04:28 PM
I'm in the US and trying to set up my Nest Cam (outdoor or indoor, battery) in the Home app of my Pixel 6. I have a 1 GB Wi-Fi setup and a mesh network throughout the house so signal is not an issue anywhere. I'm in step 1 of the setup ("Plug in your camera indoors"). After plugging it into power and the light on the front of the cam is blinking white, it states "Once it turns blue, leave it plugged in and proceed to the next step." The issue is that it never changes to blue and just continues to blink white. If I click "Next" and try to proceed with the setup, it never completes the "Connecting" step and the error message says "Make sure your Nest Cam (battery) is on and connected to the same Wi-Fi network as your phone" but as this is a brand new cam I have no idea how it is expected to be connected to any network?? I've tried to factory reset the cam (holding button on rear for 5 seconds until it chimes and goes solid white) but this hasn't made any difference. I'm having the same issue with my Nest Cam with floodlight (wired) which I'm trying to set up. This all seems very buggy and like Google just pushed out shiny-looking products which have not been tested. Looking for confirmation that others are encountering this same issue and if there is a fix or workaround?
06-10-2022 12:05 PM
Finally figured it out! Hold the rest button longer than 5 seconds and you'll get a yellow light and chimes. Now your camera is truly reset. Hope this helps someone!
09-21-2022 07:28 PM
Archie
06-10-2022 12:05 PM
09-09-2022 05:29 PM
I'm dropping by to ensure that everything is covered here. I hope that sheds some light on the issue.
I appreciate the update, Melimomma.
Archie
09-21-2022 07:28 PM
Archie
10-12-2022 01:33 PM
Archie
