Nest Cam (wired) won’t connect
Spm78
My camera won’t connect. I did the full 40 second reset. Camera is plugged into a good power source. The light blinks white but never turns blue. I have tried several times and no success.
@Spm78
If you're within the 1-year warranty period and your camera won't factory reset, you could try contacting Support about a replacement:
@Spm78
