07-11-2023 05:25 AM
I keep getting alerts of people outside the zone that I created in my nest camera.
The alerts of outside people are off and I don't know what to do.
That's my config:
07-17-2023 02:06 PM
Hi Patricknn,
I’m sorry to hear that your Nest camera isn’t working properly. Let’s check it out.
A few questions: what type of Nest cameras do you have? Do you have an iOS or Android device? Does the issue occur on multiple mobile devices or cameras? Also, are you using the Google Home or the Nest app?
Let’s try the steps below:
More information here: Set up and use Activity Zones.
Let me know how it goes.
Lance
07-20-2023 03:35 PM
Hello Patricknn,
I'm following up to see if you still need any assistance. Have you had the opportunity to try the suggestion above? If so, how did it go?
Lance
07-21-2023 05:02 AM
I had to reduce the edges of the zone because the camera is catching movements outside of it.
07-23-2023 03:55 PM
Hey Patricknn,
I’m glad to hear that this has been sorted out, and thanks for sharing your resolution in the Community. It looks like I can consider this one complete, so I will lock the thread after 24 hours unless I can help out with anything else.
Lance
