04-23-2023 10:32 AM
Can Google please do some software update that allows more intensive sound alerts options for iPhone, the standard ding dong is too soft other people have been requesting this for years, Ring has many options, i don't want to change to Ring but will have to as keep missing people at the door when im out Google Sofware people PLEASE BUILD Something, look at RING its been the same for years with no update
04-23-2023 12:50 PM
It's called android.
Iphone has always had less ringtones/sounds etc. If it bothers you that much, look for a notification app changer app.
04-25-2023 12:11 PM
Hey @jasonf .
You can change tones for your doorbell:
There will always be 6-7 default tones you can select from. During various holidays, you will get additional additional themed tones available that last for a period before and after the holiday.
Let me know if you have any further questions.
04-26-2023 03:46 AM
I dont have any options like that im in IOS older wired best doorbel 1st gen
04-26-2023 04:52 AM
Hey @jasonf .
Thanks for clarifying; the post had the Gen 2 doorbell tagged.
In that case, the same options are available in the Nest app for the Gen 1:
04-26-2023 05:54 AM
hi, i don't have any these themes options in nest or google home app, i check for updates and there are none so i am on the latest version
04-26-2023 06:01 AM
also to say im in the UK if thats the reason i dont have themes as an option
04-26-2023 06:08 AM
Thanks for the additional information, @jasonf .
The location could be the reason for the missing additional themes but I'm not positive. I'll see what I can find out and let you know either way.
04-26-2023 06:59 AM
thanks please let me, know, i keep missing people as I can't hear door ring
05-13-2023 10:52 AM
Hello jasonf,
I found an article that could be a help. Let me know how it goes.
Thanks for the help, @thisisausername and @PatrickP_Viking.
05-13-2023 11:13 AM
Hi Zoe
I checked by no option to change there only in the NEST app but also no option it's just a standard ding dong, the app needs an update. Rinf offers many different tones you can hear when out
