10-22-2021 10:16 AM
I recently purchased a Nest Doorbell Battery and am operating it hardwired to a plug-in transformer.
I have an 18.5V reading at the doorbell (same as at the transformer plugged in ~30 ft away), but the doorbell doesn't charge enough. It slowly loses charge over time, so after two weeks there is no charge left.
Is there a recommended plug-in transformer that is recommended for use with the new doorbells? I tried a 24V, but it tested at 27V and the doorbell would not charge at all. Should i next try a 20V?
This all would be much easier if there was a specified compatible transformer rather than searching amazon for different ones and "trying them out".
10-22-2021 04:22 PM
I have the same problem with a 20V, 10VA adapter. I just think Google did not design the doorbell to charge effectively from the wired connection, so the battery gradually runs out.
10-24-2021 12:32 PM
Has anyone had success fixing this?
10-25-2021 10:18 AM
Sorry for my late response. Thank you for all of your patience while waiting for a reply. I can definitely understand how frustrating your situation must be. I just wanted to make sure that your issue is addressed.
11-18-2021 10:02 AM
Hey Folks.
11-17-2021 06:34 PM
I have exactly the same issue and I am asking for a replacement to see if things would work again.
11-18-2021 03:41 AM
I just gave up and got the wired doorbell - which works perfectly. This proves the issue was never my power supply but rather how the battery doorbell operates/charges when wired.
