05-03-2023 12:33 PM
The doorbell camera used to work great (for a year). It stopped working and the green light is on but the blue light won't turn on. I've had an electrician out for the last 4 hours running new wires, making sure the chime is installed correctly, did a factory reset. and nothing will work. Is the product defective and I have to order a new one?
05-03-2023 03:12 PM
You can go to this "Contact Us" link: https://support.google.com/googlenest/gethelp
Select "Doorbell", type a brief description of the issue, then click "Next".
Click "Other", then click "Next step" until you see the contact options.
Choose to get a call or call or chat with the team, as available in your country.
05-07-2023 07:42 PM
Checking in — were you able to speak to our support team as shared by MplsCustomer? If so, how did it go? Let me know if you need anything else.
05-08-2023 11:43 AM
Thank you - yes I was able to speak with a representative, and unfortunately they confirmed the camera unit is broken/faulty and not covered by warranty any longer. I bought a "new" one (via the used market on eBay) and it works great.
05-08-2023 04:32 PM
Hi nseeks,
Thanks for updating us! It's good to know that the issue of your Nest Camera is finally found. Please let us know if there's anything else we can help you with, as I'll leave this thread open for 24 hours.
I appreciate your help, @MplsCustomer and JT.
