04-14-2024 06:03 PM
04-15-2024 08:34 AM
I've seen a couple of posts where customers applied a very small amount of WD-40 to the latch to get it unstuck.
04-15-2024 07:06 AM
I often see posts like yours in this forum about mounting problems with the battery doorbell. You could try contacting Support to see if yours needs replacing under warranty:
04-15-2024 07:35 AM
Thanks @MplsCustomer
My device is a few months out of warranty so I'm not sure a replacement will be possible. I wonder if there is a way to fix the mechanical issue since the whole door bell is still working great.
04-15-2024 08:34 AM
04-15-2024 05:37 PM
@MplsCustomer
I also found the WD-40 solution in Nest Doorbell (Battery) Stuck Latch - Fix disucssion. I tried it and it worked for me. Thanks a lot for the help!
