Nest Doorbell with Camera falling out of it's bracket
ms3625
The bracket has been installed to the wall as per instructions and videos. Now for the third time the darn thing falls off after been mounted for a month of so.
Now it's not giving a click when mounting it any more.
Can see this is not a unknown problem, any action from Google?
What to do?
7 REPLIES 7
@ms3625
You are correct; other customers have reported similar issues. You can try contacting Support using the link and instructions in this post:
EmersonB
Hi ms3625,
Thanks for reaching out here in the Community. We'd be happy to take a look into this for you. Please fill out our Contact us form with all the needed information. Let me know once you’re done.
EdmondB
I wanted to follow up and see if you were able to fill out the form?. Let me know if you have additional questions.
Edmond
ms3625
Hi
Think so, but can't figure out how to fill it. My country is missing from the list.
Best regards
Max
zoeuvre
@ms3625, thanks for getting back to us. From what country are you contacting us? Let us know so we can check it out for you. Once we receive your reply, we can continue to discuss your options.
I appreciate your help here, @MplsCustomer, Emerson, and Edmond.
Kind regards,
ms3625
I'm living in Denmark.
BR Max
zoeuvre
Hello there,
Could you send us a screenshot of what you see on the form on your end? We checked the form and saw that the country of Denmark (+45) is available.
