Nest Doorbell won't connect
grechcam
Doorbell was working great until I changed my router because our neighbours router had a stronger signal and our computers kept flopping over to their's (they are related) since then I can't reconnect the doorbell?
I have reset the router, doorbell, all the Google devices, phone and app. It gets to the connecting to an assisting device and then something goes wrong and it fails, any ideas would be appreciated
David_K
How close together are your phone, doorbell and router? For setup, it's best to move them close together.
  1. Move Hello and your phone close to your router. Within 30 cm (1 ft) is best.
  2. Plug a micro USB cable into the port on the back of Hello.
  3. Connect the cable to a USB charger and plug it into a wall socket.
  4. Wait a minute to make sure that your Hello has finished restarting.
I'd recommend following the steps in the troubleshooter if you're still experiencing issues.
David_K
grechcam
I did a full reset several times and eventually it worked, still having issues with the actual video and responding but I think this latest issue relates to the user and app settings 🙂
thanks for your response
David_K
Glad to hear that!
