10-07-2021 01:42 PM
10-27-2021 12:42 PM
Thanks for checking! My son was able to get it detached for me to get the code.
10-07-2021 02:10 PM
Why can't you remove it, there is a small hole on the underside you can stick something strong and thin in to release it. It came with a pin for this purpose if I recall correctly, but anything thin enough to fit in there and strong enough not to bend when you apply pressure ought to work.
10-07-2021 03:46 PM
Yes - I tried using both the little tool that came with it and a straightened paper clip but neither worked!! I wish I could just provide the product SN and get on with it. Ugh.
10-20-2021 10:19 AM
Sorry for my late response. Thank you for all of your patience while waiting for a reply. I just wanted to make sure that your issue is addressed. I can definitely understand how frustrating your situation must be. I would love to help you find a solution to this issue.
10-27-2021 12:33 PM
10-27-2021 12:42 PM
11-11-2021 11:45 AM
Hey Folks.
10-07-2021 02:22 PM
In the box, on the cardboard envelope thing there is also a qr code you can scan to add your Nest Hello.
