11-04-2021 07:58 AM - edited 11-04-2021 07:59 AM
Desperately looking for a replacement Nest Hello metal mounting bracket that our contractor broke. I contacted support but because it’s out of warranty, they won’t provide a replacement. I even offered to pay for it but they said it’s not possible. Nest support has always been awesome but this is really disappointing because now the doorbell is useless without a part that probably costs a few dollars. I ordered a replacement on Amazon but they are all mounts and wedges that don’t come with the bracket so now I’m stuck. Any suggestions on where to get this part??
11-04-2021 08:33 AM
I am terribly sorry to hear about your Nest Camera bracket issue! I can imagine it’s been quite frustrating being without a working device. We will need to look into this further in order to best assist you.
We'll be reaching out to your email on file to collect some information from you. Please respond as soon as you can, so we can get the process started.
Please let me know if you need any further assistance!
11-06-2021 03:57 AM
Good luck waiting for Brad's help!
11-06-2021 05:53 AM
Yea, I got an initial email asking for some info and nothing after that.
11-06-2021 06:39 AM
Sadly the so called senior Google people are pretty useless, BUT there has to be one out there that can help!!!!!!!!!!!!!!!
They look for the easy question, answer that, then hide away again.
Brad, well it's pointless waiting for him, isn't it Brad?????
Come on Brad - REACH out for BJacobson with longer arms!!!
11-06-2021 06:40 AM
UK or USA?
11-06-2021 07:03 AM
US
11-06-2021 10:02 AM
That's a shame, as I have one here, but I'm in the UK.
Waiting for anyone from Google will be a challenge, so Ebay could be the best way.
Like you say, for a small of amount of cash, you now have a bell which is as good as useless without a simple cheap metal component.
11-06-2021 11:22 AM
Still holding out support will come through but not holding my breath. Thanks for the tip, I appreciate it
12-23-2021 06:42 AM
Don't suppose you still have that bracket do you, I'm in the UK and need one 🙂
11-04-2021 01:12 PM
I think your best bet is to buy a used HELLO from Ebay. Maybe you can find someone selling a broken camera only because you need the bracket. Good luck.
