01-14-2022 10:58 AM
Hello my nest hello doorbell (wired) wall plate/mounting plate top tab broke so it doesn't lock into place. This has happened because I need to keep resetting it. Seeing as it's very cold here (mn) it finally decided to not work. Where can I purchase an OEM mounting plate at? I prefer to stay away from aftermarket especially with such an important device. Thank you
Chad
01-14-2022 11:02 AM
Thank you for your patience. If you are seeking a replacement, please first fill out this form so we can collect some important information from you. Once the form is submitted, you will have your case number. Please be aware that this thread will be locked.
