12-30-2022 09:09 AM
My nest indoor cam went offline suddenly and I couldn’t get it to come back on. I’ve restarted it in the home app, unplugged it for a few hours and pressed the reset button on the back for 5 seconds. Nothing seemed to work so I attempted a factory reset. The lights blinked yellow 4 times then turned a solid yellow. The light went out and came back on white with a sort of pulsing. I waited for it to turn blue but it never would. I’ve now reset it at least 5 times and deleted it from the app with the same result. Anyone know what’s going on?
a month ago
Sorry to hear you're experiencing this, as I can imagine it has been an inconvenience. I would love to look into this further for you. It sounds like your camera did go through the Factory Reset process based off of the lights. Here is an article that goes over what the lights mean. Please let me know if you still need assistance.
3 weeks ago
Hello Brad,
Thanks for the reply. I reviewed the article and found that “blinking or soft pulsing white light = downloading update/software update”. Essentially that’s what I’ve been dealing with, a white pulsing light that keeps returning after reset. Note: Currently whenever I unplug and plug my camera back into the wall socket, it does play a startup chime before the white light starts pulsing. I’m still stuck, and based on the article, it seems like it’s stuck in a update loop.
4 weeks ago
@CWGComm It's us again. I'm bumping up this thread to ensure that everything is covered here. Were you able to read the information and check the link shared above? In case you have an update, you know where to find us.
I appreciate the help, Brad.
3 weeks ago
I’ve reviewed the info and have not been able to resolve the issue yet.
3 weeks ago
Hello CWGComm,
3 weeks ago
Yes, please keep it open. I still have not been able to figure this problem out.
3 weeks ago
3 weeks ago
I appreciate the help here, Emerson and Brad.
2 weeks ago
