10-01-2023 06:33 PM
I can’t get my doorbell chime to play on the nest speaker. I have the visitor announcement turned on and it won’t allow me to turn the chime feature on.
10-01-2023 06:59 PM
The "Indoor chime" option is intended to enable ringing of an indoor doorbell chime, and is disabled if your battery doorbell is not wired to an indoor doorbell chime.
Is "Do not disturb" turned on for your Nest speaker? If so, you need to turn it off. Are your speaker and doorbell in the same Google Nest "home/structure"?
10-01-2023 06:59 PM
10-02-2023 02:19 AM
Unfortunately we do not have an indoor hardwired chime so I purchase the nest as a substitute so we can hear when someone is at the door.
The nest is not in Do not disturb mode.
10-02-2023 07:13 AM
If your Nest Mini is in the same Google Nest "home/structure" and you are NOT getting visitor announcements, you could try contacting Support using the link and instructions in the post below:
10-04-2023 03:15 PM
Hello everyone,
@Sweisz30, thanks for reaching out to the Community. I’m sorry to hear that you're having issues with the visitor announcements on the Nest devices. Have you seen MplsCustomer’s suggestion above? If yes, how was it?
If you haven’t done so already, please try the troubleshooting steps below:
Let me know how it goes.
Here’s a handy guide to learn more about how to get doorbell visitor announcements on a speaker or display.
Thanks for chiming in, MplsCustomer.
Lance
