06-15-2022 05:32 AM
This is an OLD problem that I still cannot find Nest/Google providing a final solution other than dumping the camera and throwing away $200. I have 2 Nest cameras - one indoor and one an outdoor. Only the outdoor camera fails to come back online after a power failure. No problem with the indoor camera. Only a reset by manually unplugging it from the electrical outlet fixes it. This is at a property of mine an hours drive away and defeats the purpose of using it for security. Is there a FIX? Typically these things are a firmware issue and the device needs a firmware update - IS THERE ONE AVAILABLE? Unless I missed it, other threads I have read say nothing about a fix and support just mostly walks away from it. Not acceptable.
06-15-2022 07:29 AM
As a band aid fix until Google fixes this, you might consider using a smart plug you can turn off and then on remotely.
06-15-2022 10:53 AM
Great idea. I happen to have one laying round and will give it a try. Many thanks!
06-20-2022 04:50 PM
Hey upoutdoorzman,
Thanks for the help, MplsCustomer and LSimon. I'm dropping by to ensure if everything is covered here. Hope that sheds some light on the issue.
Archie
06-15-2022 07:55 AM
This is a perennial problem. We had a power outage yesterday, and I had to unplug two of our Google Nest cameras (the first gen non-battery ones) and plug them back in again before they'd come back online. I did not have to unplug our oldest camera, or the doorbells, or our one new Google Nest Camera (Battery), which is plugged in with the optional power cable.
06-22-2022 03:39 PM
Same problem. I have 1 Google Nest cam and 2 Ring cams. The power goes out and the Ring cams come back online. The Google Nest cam does not. I was going to replace my Ring cameras with Google because I have multiple Google homes. Unless Google actually responds to the issue, I will be keeping Ring and replacing the third cam with Ring instead.
06-22-2022 09:50 PM
Hey deeaski,
Sorry to hear if you're having an issue with your Nest Cam Outdoor. Let's check — is this the first time you encounter this issue? Did you check the status light of your camera after the power outage? Also, are you using the original power cable and adapter that came with it?
Archie
06-23-2022 07:51 PM
No not the first time I’ve had the issue. Yes I’m using the original power cable. The issue is only when we lose power. The camera does not automatic come back online unless we un plug it and plug back in or go through the painful setup process. Not at all user friendly.
06-29-2022 05:53 PM
Hey deeaski,
This is not the experience we'd like you to have. To confirm, are you using a power strip to turn on your Nest Cam Outdoor? If so, try to plug in your camera directly to a wall outlet.
Archie
06-29-2022 07:50 PM
This is a perennial problem. None of our cameras are plugged into power strips and two of our non-battery cameras did not come back online after a power outage two weeks ago until I unplugged them and plugged them back in. Our oldest camera and our doorbells came back online without having to be unplugged and plugged back in. This happens whenever we have a power outage.
07-14-2022 09:04 AM
Best regard,
06-29-2022 08:09 PM
Mine is plugged directly into an outlet. A new receptacle with tight grip on the plug.
07-18-2022 08:33 AM
Just checking in on this thread and the activity on it. We'll leave this topic open for another 24 hours in case there are any follow up questions or comments.
07-17-2022 10:28 AM
I have figured out the issue and it is not the Nest Cam! There was something wrong with the electrical outlet. Since that has been fixed, there are no issues.
07-08-2022 07:00 PM
I just had a power failure & one of my cameras won't come back online even when the power is disconnected. It's hardwired to a switch. I cut it off for 3 minutes multiple times with no luck. Is there another solution?
07-17-2022 09:44 AM
I've had to unplug the outdoor cameras from their middle connection point (the USB part) rather than the end connection at the outlet to get mine working whenever this happens. For interior cameras I have to again unplug the USB cable from the outlet plug and not just unplug the wall outlet plug to get the cameras back to working. I'll be replacing all of my nest cameras in the near future because of this issue.
07-17-2022 03:58 PM
I'll keep that in mind for next time. I busted out the ladder & reset it...😠
