04-09-2022 12:54 AM
04-13-2022 01:48 AM
Thanks a lot . my situation is a bit different .
I reset it to factory settings and all good now
thanks again 🙂
04-09-2022 03:52 AM
Happened to me. I purchase the nest doorbell but took it offline pending my new door. I had set it up and ready to go. Once I tried to connect the nest outdoor cam, I ran into the same issue as you. As soon as I connected the nest doorbell camera, only then was I able to add a new camera. Hope this helps.
04-13-2022 01:48 AM
thanks again 🙂
04-12-2022 11:13 PM
I appreciate the help @Supercat. Let's get this sorted out. A few questions:
You can also check this article on how to Troubleshoot Nest camera and doorbell setup messages for detailed steps.
Steve
04-13-2022 01:49 AM
Thanks . All good now
04-14-2022 08:22 AM
Hey Folks.
I am glad to hear that the OP's issue is resolved! At this time, I'll go ahead and lock this thread. If you're still experiencing problems, feel free to start a new thread and we'll be happy to help.
