01-08-2023 03:32 PM
I have a wired nest doorbell. Purchased just under 3 years ago.
3 weeks ago it stopped working.
I tried to:
The power source and transformer are working so it must be the camera.
Surely this should last longer than 3 years?
The same issues and timescales as others on this community.
Any ideas of what else it could be?
thanks
01-13-2023 10:14 AM
Sorry to hear you're experiencing this, as I can imagine it has been an inconvenience. If your device is outside the 1-year warranty period, I am afraid that we would not be able to replace it. If you wish to look into your options, I would ask that you please fill out this form, and a higher tier of support will reach out to you after it has been filed out.
01-18-2023 06:23 PM
Hey amacaskill,
Thanks for trying to isolate the issue with your Nest Hello doorbell (wired). Let’s sort this out — a few questions: what’s the voltage of your transformer? How’s the temperature of the doorbell (warm, hot, cold or normal)? What country are you located in? Has there been any recent power outage in your area? Also, has it been exposed to direct sunlight?
Here are some troubleshooting steps you can try:
Important: When the doorbell shows a blue pulsing light when connected to a computer, it means it’s working. There may be issues on your wires or transformer. I recommend scheduling a visit with our partnered Nest Pro.
I appreciate the help, Brad.
01-19-2023 10:12 PM
I appreciate the help, Brad and JT.
Archie
