Nest Wired Indoor Camera
Foxcon123
Purchased a nest wired indoor camera.  Live in an apartment complex that requires all devices be whitelisted on spectrum community wifi.  This requires the Mac address but looks like the only way to get the Mac address is connecting the device to wifi.  Cannot connect the device to wifi without the Mac address.  Brilliant!  Setting up on Hotspot isn't working.  Just want the Mac address.  Google doesn't respond to inquiries.
2 REPLIES 2
@Foxcon123
That's a real Catch-22 dilemma.
The post below from this forum has a workaround posted by "paigemetzman". They had a friend create a hot spot using their phone, and then the Nest customer connected to that hot spot. You can check it out and see if it works for you.
https://www.googlenestcommunity.com/t5/Speakers-and-Displays/How-can-I-find-my-Nest-and-Mini-MAC-add...
Thanks for visiting the Community. Since this thread hasn't had activity in a while, we're going to close it to keep content fresh.
We hope you were able to get the help you need, but if you're still having trouble, please feel free to submit another post, and provide as many details as possible so that others can lend a hand. Hope this helps!
