Nest Wireless Doorbell - Multiple Hubs
ShalomLEJ
I have a wireless doorbell, a Hub Max, and a Hub (2nd Gen). When the doorbell is pressed, I can answer on the Hub Max, but it does not show someone on the Hub. Is there a way for doorbell events to be shown on both at the same time?
ShalomLEJ
Found the issue. For some reason, Do Not Disturb was active for that Hub. Turned it off and all is now working. To Google: it would be helpful if there were some check, or screen, that showed which devices will receive these alerts, and which ones will not!
ShalomLEJ
To Google again:  even a visual indicator on the screen(s) that broadcasts were being blocked when one was made would lead customers to the solution quicker.
ai
Hi @ShalomLEJ
We're sorry you had issues with your doorbell and its connected devices, but we're glad to see that you found the culprit. As this issue was resolved, I will be closing and locking this thread. If you have any new questions for us, please make a new post. Thanks!
Ai
