01-23-2022 06:57 PM - edited 01-23-2022 06:57 PM
Hi, this might be a noob question but can I get notifications from my nest cam battery on google hub max and not just from the mobile phone?
01-24-2022 04:21 PM - edited 01-24-2022 04:22 PM
I'm not aware of any way to do that. It can receive notices from the Doobell (Battery) on button presses, but I think only the Home app can get movement/event notifications from any of the new cams.
I hung an old tablet on the wall for this purpose. It works pretty well (and also useful for other things).
04-28-2022 02:58 PM
While you can't get notification on your Nest Hub Max from your Nest Camera(battery), you can stream it using your Nest Hub Max. Check this link for more information. If you still need help, feel free to submit another post and provide as many details as possible so that others can lend a hand. Hope this helps!
Kind regards,
Alex
