05-15-2022 05:44 AM
Hi all
all of my cameras have issues. They have all been working ok for months. They are all connected via proper external nest cam power supplies. One works for a few days and states “battery is empty” and and I am unable to access it. It then comes back online after two days and works again for a few days.
Then today the other two have played up - going offline. I have been out and checked - the green camera light is on but I am unable to connect - they are 3m from router- I have unplugged power and left for 5 minutes then re connected and one comes on again for a few hours then off again. Can you suggest a remedy or do I need to organise replacements
Brian
07-27-2022 03:03 AM
I have managed to setup the camera but could only see 2.4GHz network even though my phone was on the 5GHz network. I couldn’t setup using IOS so used my Android phone and had to use the setup code as scanning failed.
Please keep this open for another 7 days and I will advise if they go offline again.
thanks
Brian
05-31-2022 11:23 AM
I apologize for my late response and thank you for all of your patience while waiting for a reply. I understand how frustrating your situation must be, and I would love to help however I can. Do you still need assistance?
05-31-2022 06:41 PM
06-09-2022 11:35 PM
Hey Brianj38,
Thanks for trying those steps. A few questions: are you getting any error messages? Are there other devices connected to the same Wi-Fi where the camera is connected to? Also, are there devices or appliances (such as baby monitors, microwaves, cordless phones, etc.) near the camera?
Archie
06-09-2022 11:42 PM
Hi
the nest cams are on the same wifi SSID as the nest hub, tv and mobile phones. Nothing has changed with and devices, no new devices and no network changes in the past 12 months.
these cameras are outside so nothing nearby like white goods etc
06-16-2022 06:16 PM
Hey Brianj38,
Thanks for the information. Are you using a dual-band router (2.4GHz and 5GHz)? If so, which band are they connected to? Also, you can check out this link to Troubleshoot offline Nest camera or doorbell.
Archie
06-20-2022 05:59 PM
Hey Brianj38,
I wanted to follow up and see if you are still in need of any help? Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
Archie
06-20-2022 06:05 PM
Hi
yes I am still having offline issues
06-20-2022 06:07 PM
07-07-2022 10:32 PM
Hey Brianj38,
Sorry for the delay. Since your camera is near from the Wi-Fi router, it's best to connect it to 5 GHz. Also, what's the status light of your cameras?
Archie
07-12-2022 08:50 PM
Hey Brianj38,
Archie
07-13-2022 10:30 PM
Hey Brianj38,
Archie
07-14-2022 11:15 PM
can you please this open for 7 more days as I have just reset and changed the 3 cameras to 5GHz net work on router as they were on the 2.4 GHz range - I would like to see if that helps.
thank you for your message.
rgds
Brian
07-19-2022 06:24 PM
Hey Brianj38,
Understood. Let me know how it goes.
Archie
07-26-2022 10:04 PM
Hey Brianj38,
Archie
07-27-2022 12:03 AM
Hi
i am having issues setting one of my cameras up again as it was on the2.4GHz network and the other two were on the 5GHz network. I factory reset and have the slowly flashing blue light. I am running through adding but gets “Something has gone wrong”. I have re done this several times and ensured my phone is on the correct network but still the same. Please assist as it’s getting annoying now.
rgds
Brian
07-27-2022 03:03 AM
thanks
Brian
