02-18-2022 07:41 AM
I bought 3 nest cam indoor wired 2nd gen. First of all, it's a piece of sh*t.
But i am trying to live with it. As soon as I leave home (the same WI-FI that the cams are connected to) the picture doesn't show. When I am in the view where I see all 3 cams there is no picture at all. When I choose a specific cam it takes a few minutes and i get a 2-3 second show and then it says "connecting" again. So and i get a few few views every other minute.
I have no problem with bandwith, I hade 250mbit/s steady connection and no problems with any other device.
Any sugestions?
02-21-2022 01:48 PM
are you within the return window? If so, I would 10000% recommend returning it. Did you know you can't use 2-way voice on the doorbells? It doesn't work if you have a samsung phone. @User123456 has known about it for over a year and hasn't done anything about it. So, I have an expensive doorbell that will not allow me to even talk to folks at the front door. Useless! Return it if you can!
05-03-2022 10:43 AM
Thanks for visiting the Community. Since this thread hasn't had activity in a while, we're going to close it to keep content fresh.
We hope you were able to get the help you need, but if you're still having trouble, please feel free to submit another post, and provide as many details as possible so that others can lend a hand. Hope this helps!
