Nest cam pro set up
Annamarie016
I cannot find any instructions to set up nest cam pro other than what is in the box and that does not work.  Camera is not automatically appearing to add device and there is no QR code to scan.  Directions for drop cam say to enter setup code but when entering code manually, it will not accept ant letters only numbers
EmptyNester
Silver Product Expert
Hi Annamarie,  I'm an end user like you.   Just to confirm you are using the GOOGLE HOME app and not the NEST App.  The new cameras only work with the Google  Home app. And if you already had that on your phone be sure to confirm you are using the newest version of the GOOGLE HOME app by going to the app store and searching for it. If it says OPEN then you have the newest version.  If it says UPDATE then  you should do that.
Let me know if this helps
SteveT1
I appreciate the help @EmptyNester. Just checking in to see if the troubleshooting steps shared helped. If you have other questions and concerns, feel free to let me know.
Steve
SteveT1
We haven't heard any updates from you. I'll go ahead and lock this thread in 24 hours. If you're still in need of assistance, feel free to start a new thread and we'll be happy to help.
Steve
