Nest doorbell puck does not work for gen2 wired doorbell
gregboggus
Hi, after installing the doorbell and the chime puck the chime did not work. I tried waiting 30 min and trying again and still no inside chime. I then decided to try with the puck not installed and the inside chime worked. Now with it not plugged in the analog chime is bouncing around (not chiming but sounds like a clock ticking). I had read that maybe it was faulty and could be replaced. I am wondering if I could get a replacement puck that could maybe fix the problem?
Gregory Boggus
@gregboggus
You can try contacting Support about a replacement by starting with this link. On the "Resources" page, just click "Next step" to get to the page with contact choices (chat or phone).
Note also that many customers in this forum--including us--have upgraded from a 16V 10VA transformer to a 16V 30VA transformer to get either their older Google Nest Hello Doorbells or their newer 2nd Gen Google Nest Doorbells to work, even though this is more than Google Nest's minimum requirement (https://support.google.com/googlenest/answer/9247132).
EdmondB
Hello gregboggus,
I'd like to jump in here and check if you've seen MplsCustomer's response. Let us know if you need more help by replying to this thread.
Thanks for the help, @MplsCustomer.
Edmond
gregboggus
Yes thank you @MplsCustomer I was able to get a hold of some through the link you posted. Thank you!
Gregory Boggus
EdmondB
Hi Gregboggus,
I just want to make a follow-up. How does it go when you talk to our support? Let me know if you need more help.
Edmond
EdmondB
Please let me know if you have other questions or concerns as I will be locking this after 24 hours. Feel free to start a new thread and we'll be happy to help.
Edmond
