12-30-2021 05:13 AM
Hi
I have recently installed a nest hello doorbell (wired) the product works correctly. However , we are experiencing a loud humming/buzzing from the transformer ? Does anyone know what the likely issue is and solution?
I was wondering if the issue is simply a faulty transformer and just replace that
Second question- can you use a 24v dc supply or does it have to be ac supply I'm using a ac supply)
Many thanks - the noise is very annoying !
Thanks
Paul (located in uk)
03-29-2022 11:39 AM
No problem Brad. Looks like issue was a faulty transformer which we replaced . Still a alight hum but much better. Thanks for reaching out
03-29-2022 08:48 AM
03-29-2022 11:39 AM
03-30-2022 10:21 AM
Hey Folks.
I am relieved to hear that this issue is resolved as the transformer was replaced! At this time, I'll go ahead and lock this thread. If you're still experiencing problems, feel free to start a new thread and we'll be happy to help.
