Nest drop cam pro will not setup using my computer or iPhone. Error code suggest a security problem?
Mark2022
8 REPLIES 8
RRG
I also can't set mine up on computer or phone...and they both just worked perfectly at my previous address...and this isn't a wireless connection issue as my Comcast router can see it and says its connected. But I still get the error even after rebooting router.
Restarting and factory resetting your Google Nest camera or doorbell will have different results:
Restart: Keeps all your settings, and it should reconnect to the same Wi-Fi network. This is helpful if it ever becomes frozen, has trouble reconnecting to the internet, or isn't working normally.
Factory reset: Erases all your settings and options, and restores its factory default settings. It will not automatically reconnect to Wi-Fi and you'll need to set it up again.
You can find this information, plus additional information on this process here. Please let me know if you have further questions.
RRG
nope, can't restart or reset a dropcam pro...but thanks for not reading my issue. Why don't you look up serial number on your end and reset it? Its probably still tied to my old account or something. I deleted that account when I moved. Now it won't setup. seems like a scam to make me buy a new one.
@RRG
There is no such option to reset it from my end. I would suggest you reach out to Support for further assistance.
DocM
Hopeless.
GarrettDS
Have a great day,
Garrett DS
