Nest outdoor cam with flood lights
Eterymayzlin34
Hi, i got a message on my Google home app that my outdoor camera with flood lights is at 76% and I need to charge it, but I don't know how. Can someone help please
@Eterymayzlin34
Is your floodlight camera on a circuit with a switch where the power is being turned off?
If the power is always on, the battery should never need charging. We've had a battery camera (the same camera used in the floodlight fixture) for over 3 years--plugged in with the optional power cable--and it's never needed charging.
I believe the floodlight camera does NOT come with a charging cord, since it's always supposed to be connected to power.
Yes it's on a cord , and yes the switch is always on, ok great I get it and no charging cord came with it you're right. Awesome,  thank you so much , you've been a huge help
@Eterymayzlin34
I'm not sure I've been of much help.
If your camera is always connected to power, the battery should not deplete. Perhaps it's worth contacting Support to determine whether you have a defective camera that needs replacing under warranty:
4. Under "Resources", just click "Next step". (Clicking one of the listed links will bring up a Help page.)
Thank you, that's what I thought also cause my other outdoor Nest cameras don't need anything lol just up there and work perfect but the fluid light one was saying that but since it warmed up outside,  it hasn't sent me a message. But yes you did help, thank you again.
